What overclock settings should I put for my R7950? Im not sure if I put too much because suddenly games become really laggy  then I check my overclock and it actually downclocked to 550mhz and 600mhz for memory. My 7950 is a Sapphire OC. Should I use Afterburner or AMD overdrive?
https://linustechtips.com/topic/86307-r7950-overclock-settings/
I'm running 1200MHz core and 1265MHz memory at 1.17 volts. But that is extreme though. Try like 1000MHz core and go up from there.
Personal Rig
i7 4790K | Asus Z97I-WiFi | CM 280L | Sapphire R9 290X Tri-X | Kingston ValueRAM 2 x 8GB | 128GB Samsung 840 Pro | 2TB Seagate SSHD | Seasonic Platinium 660W | Bitfenix Prodigy
https://linustechtips.com/topic/86307-r7950-overclock-settings/#findComment-1171901
I think 1150/1500 is pretty easy to aim for as long as you are voltage unlocked. Might need up to around 1.25V. Also, I recommend afterburner.
Current rig: i5 4670K | GTX 670 | Asus Z87I-Pro | Silverstone Strider Plus 600W | Custom mITX case | Seagate Barracuda 3TB | Samsung 840 120GB | G430 | CM Storm Quickfire Pro - MX Red | LG 21.5"
https://linustechtips.com/topic/86307-r7950-overclock-settings/#findComment-1171907
How exactly do I unlock voltage? Is that the slider in the Amd overdrive?
In afterburner there is a voltage slider, I don't use AMD Overdrive. I would recommend using GPU-Z running in the background to monitor actual voltage usage to make sure your settings are working. Here are the settings I used:
https://linustechtips.com/topic/86307-r7950-overclock-settings/#findComment-1171933
If Afterburner doesn't work, use Sapphire Trixx or Asus GPU tweak. They have more support for voltage control.
Personal Rig
https://linustechtips.com/topic/86307-r7950-overclock-settings/#findComment-1171935
