hi everyone reading this.
can someone help me cut the cost down by not losing performance?
thanks. I would also appreciate help on any compatibility issues.
build - https://ca.pcpartpicker.com/list/hYH6Yr
the gpu i will use is not on pc part picker. - https://www.amazon.ca/ASUS-GeForce-Dual-fan-Graphics-DUAL-GTX1070-8G/dp/B01JHQSZ5Y/ref=sr_1_3?ie=UTF8&qid=1511235790&sr=8-3&keywords=asus+geforce+gtx+1070
the pc part picker price is not correct. There should be $200 more added for the monitor in the total.
https://linustechtips.com/topic/862612-gpu-and-cpu-based-workstation-build/
