My computer screen gets all screwed up, like artifacting, whenever I plug it into the Graphics Card. I have a Nvidia 1060. At first we thought it was the graphics card dead or loose, so we got a new one, same problem. Then we thought it was the motherboard, which I highly doubted, THEN we figured out it's only a problem on certain monitors.. Like I have 2 monitors upstairs that have the problem, but the one monitor downstairs works perfectly.
Solutions I tried:
Factory resetting monitor
Switching up cables
Getting a new graphics card
https://linustechtips.com/topic/861088-complicated-computer-problem-please-help/
2 minutes ago, heimdali said:
You are aware that monitors are not hotpluggable?
What? You can connect/disconnect monitors while a computer is on.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
3 minutes ago, heimdali said:
Sure you can do that, and it might damage the monitor or the graphics card or both.
WTH? I’ve never heard of that on any modern system. I do that all the time on systems that can’t go down. I don’t know where you’re getting that from.
Main System: Phobos
Can you show where it says in the specification of VGA, HDMI, DVI, display port and what else there might be connections that they are designed to be hotpluggable?
It´s not even a problem because you can turn off either the monitor or the computer to plug/unplug it.  I always do that.
