So, i want a laptop for editing, and light gaming (Overwatch, CS:GO, c.. cuphead and etc.). Preferably with an NVMe SSD with a high budget of 1800$
I found this one: http://a.co/0luriRN
I am not sure if the MX150 4Gb is enough... please tell me your opinion on this or suggest me another one.
Thanks in advance
https://linustechtips.com/topic/860059-help-laptop/
3
I think with your budget you can go for Acer Predator 15, your's laptop is good, but I'm not sure about MX150. Btw, if you are going to play Cuphead you will need an extinguisher
https://linustechtips.com/topic/860059-help-laptop/#findComment-10701147
Just looked it up. They say that the MX150 is 25% faster than the 940mx so I am ok. I just need around 60fps and it seems that it does just that.
Also can you give me the link to the acer laptop that you were referring to?
https://linustechtips.com/topic/860059-help-laptop/#findComment-10701317
Thanks in advance
go for a gtx 1050ti or higher wouldnt suggect going for a mx150 not the best graphics card
https://linustechtips.com/topic/860059-help-laptop/#findComment-10701539
1 hour ago, BlitzThePcSpecalist said:
Hey Obysloukidel,
I would personally suggest something like this: https://www.razerzone.com/gb-en/gaming-laptops/razer-blade-pro#shop
Anything from Razer would be a good idea for the kinda things you are planning to do.
you dont need a high spec razer to play games like csgo a gtx 1050ti or higher would easily do the trick
https://linustechtips.com/topic/860059-help-laptop/#findComment-10701546
Thanks in advance
For that price you can buy laptops with more powerful hardware like Dell XPS 15 (there are many options, will not list out here)
Lol, Razer makes shit laptops, poor internal quality, poor QC, poor support
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/860059-help-laptop/#findComment-10703715
Yeah, but you can take Predator with 1070GTX https://www.amazon.com/dp/B01MR2WT9P/ref=psdc_13896615011_t3_B01ER4AQJE
https://www.acer.com/ac/en/US/content/predator-15-series
https://linustechtips.com/topic/860059-help-laptop/#findComment-10704728
Thanks in advance
https://www.amazon.com/gp/aw/d/B074JG62PW?psc=1
this is within your buget great specs
https://linustechtips.com/topic/860059-help-laptop/#findComment-10705751
