ok this will be my first time building a pc i know what i need but for my budget i would need help. i have around 250 for a pc now thats not a lot for some but i dont care for high setting or even medium i like good fps over looks. so my idea was a intel core 2 quad or a earlier gen i5 and maybe 4 gb of ram but i would like 8. storage i have a harddrive that has what i need on it so i need help with a gpu along with a power supply, case , and mother board so if someone could help me for gpu. my work load is light to mid gaming and a little of light photo and video editing as well (for my YouTube channel) plus a little of music with fl studio so any help with pc parts like gpu and may be a procseser for this work load is much welcome
https://linustechtips.com/topic/859828-building-first-time-pc/
I think used components would probably be best considering price restrictions, so it depends a ton on where you live. I would go full on scrapyard wars and search craigslist and ebay, see what you can find. Maybe look for a 3rd gen i5 and a 780ti or something.
Tech, engineering, gaming and promoting the metric system. These are my things.
Lover of Linux.
Currently rocking a ThinkPad L13 laptop tricked out with an i7, running Windows 10.
PC Specs:
CPU: Intel i7 6700
GPU: Nvidia GTX 1070
Motherboard: Asus Z170 A
RAM: Corsair Vengence 16GB
https://linustechtips.com/topic/859828-building-first-time-pc/#findComment-10698531
Well I would suggest possibly hopping on AM4 so you have a platform to build on. Maybe get a case later. See if you can find cheap DDR4.
PCPartPicker part list: https://pcpartpicker.com/list/yvLdsJ
Price breakdown by merchant: https://pcpartpicker.com/list/yvLdsJ/by_merchant/
CPU: AMD - A8-9600 3.1GHz Quad-Core Processor  ($70.15 @ Newegg Marketplace)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($74.33 @ OutletPC)
Memory: G.Skill - NT Series 8GB (2 x 4GB) DDR4-2400 Memory  ($80.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($41.77 @ OutletPC)
Case: Rosewill - SRM-01 MicroATX Mini Tower Case  ($19.99 @ Amazon)
Power Supply: SeaSonic - S12II 520W 80+ Bronze Certified ATX Power Supply  ($37.99 @ SuperBiiz)
Total: $325.22
Generated by PCPartPicker 2017-11-14 20:39 EST-0500
What you want to find is an old business machine hopefully with more standard parts, then just slap in a used GPU, something with an i5 or i7 preferably.
A8 benchmarks. he later puts an 1800X into the super cheap system
https://linustechtips.com/topic/859828-building-first-time-pc/#findComment-10698537
Also, windows alone costs $70-100, so maybe try linux or great if you already have a copy of windows. (if you want to go for new build)
Lover of Linux.
PC Specs:
CPU: Intel i7 6700
https://linustechtips.com/topic/859828-building-first-time-pc/#findComment-10698551
https://linustechtips.com/topic/859828-building-first-time-pc/#findComment-10698614
Lover of Linux.
PC Specs:
CPU: Intel i7 6700
https://linustechtips.com/topic/859828-building-first-time-pc/#findComment-10698665
Lover of Linux.
PC Specs:
CPU: Intel i7 6700
https://linustechtips.com/topic/859828-building-first-time-pc/#findComment-10698683
