Issue Transitioning Between Monitors?
Hey guys,
So I have an ASUS MG248Q (24", 1080p, 144Hz) monitor and a Samsung UE510 (28", 4K) monitor and noticed that there's a misalignment between the two when I try to move my mouse over? For example, the top quarter of the 4K monitor doesn't seem to connect with the other monitor and I need to move it down before it crosses. Is there a way to fix this software to adjust the scaling issue? I'd prefer not to downgrade the resolution on the 4K monitor if possible. Thanks in advance!
https://linustechtips.com/topic/859766-issue-transitioning-between-monitors/
1 minute ago, Legendarypoet said:
You can move the monitor ^in display properties to be more accurate, but the resolution difference will not allow for it to be 1:1.
I've tried aligning the monitors in display settings but it still doesn't feel natural moving over since there's dead space where it doesn't register. I was thinking more along the lines of a third-party software solution or some obscure setting in Windows 10 if it exists?
