Hey,
Just been playing around with 5Ghz overclock. Was stable at 1.330v so I decided to use adaptive mode to get more power saving. I forgot to change one setting and it used Asus auto SVID which took the CPU to 1.440v. I noticed it right away in HW monitor and changed settings and it's all good never going over 1.360v now. Any issues running that high voltage for a short time? I wasn't stress testing, as I know not to do that with adaptive.
Also, Aida64 says 1.344v highest
HW Monitor 1.360v
Which is the most trustworthy? They are all the latest version.
Thanks for any help you can give.
https://linustechtips.com/topic/859628-8700k-voltage/
No. I trust HWinfo more than others
Desktop benching:
https://linustechtips.com/topic/859628-8700k-voltage/#findComment-10696439
