10 minutes ago, Trevor87 said:
Have you checked the Lan cable on anther pc to see if it the cable also you could use voltage meter to check the cable is good.
I just switched to another lan cable, after 30 mins it didnt work again so the cable is fine
6 minutes ago, Trevor87 said:
Because it could also be a driver problem or a security problem or a settings problems or it could be your Lan card on your pc because your wireless is different all to gather
i just updated my drivers due to a fresh install of windows, it might be a security problem but i dont know anything about internet and lan besides the speed
