Need help on NAS solution
Go to solution Solved by jwworker201,
12 minutes ago, checkmate007 said:
What exactly do you mean by you can do more with it?
You can run web servers or can set up your owm cloud via owncloud/nextcloud for example. Or run Plex on it if I recall correctly. But if you just want to transfer files the WD should do as well; I can't tell you how reliable the device is. I only worked with DIY methods and Synology before.
I personally would prefer an DIY solution but if you want something which just works and you don't have much effort with (and is fairly cheap) I think the WD thing will do the job.
Over the years, my collection of external hard disks have gotten larger, with a number of smaller drives. As it was getting difficult to track the files on these drives, I plan to get a NAS with 4TB (for each drive in RAID 1).
Currently, I am split between the two options right now:
  1. Synology DS516J with 2 x WD Red 4TB (US$514 equivalent)
  2. WD My Cloud Mirror, Gen 2 with 2 x WD Red 4TB included (US$370 with ongoing promotion)
There are a number of things I want to clarify and ask:
  • Will I be able to access the files on these devices using Windows Explorer or Finder and use a normal media player such as VLC to play videos off it smoothly? (1080p FHD)
  • Which of the two would you recommend considering the price of each?
https://linustechtips.com/topic/858203-need-help-on-nas-solution/
I wouldn't go for an RAID 1 Setup, I'd go straight for something RAID 5 like because it brings in more security for you.
You can do way more with the Synology box so I would go for that. But have you ever thought about building your NAS by your own and running unRAID or FreeNAS on it? Would be more powerful, more flexible and way cheaper. But if you want to go for an prebuilt solution go for the Synology even if it is more expensive.
I am personally not that experienced with prebuilt solutions but that should be fine on both devices. The encoding happens on your playback device and not on your NAS (at least if you don't run Plex with transcoding on it). Throughput should also be doable with full Gigabit speed on both devices.
Hope this helped ;)
Main Rig
CPU - i7 6700 | RAM - 16GB (2x8GB) G.Skill, 16GB (2x8GB) Crucial OEM | GPU - MSI GTX 980 Gaming | PSU - Cooler Master G450M | Storage - 1x 256GB Samsung SM951 (NVMe)(System), 2x 500GB Samsung 860 EVO (Striped) | Case - Fractal Design Define R5 (with TG side Panel) | OS - Windows 10 Pro
NAS / Docker Host
CPU - Xeon E3-1220v3 | RAM - 16GB (2x8GB) Kingston ECC | PSU - Enermax Revolution SFX 550W | Storage - 3x 4TB WD Red, 1x 2TB WD Red, 4x 3TB Seagate Constellation, 2x 250GB Samsung 850 EVO (Cache) | Case - AVID Unity Media Engine (3U Rackmount) | OS - UnRAID OS Pro
VM Host
CPU - Xeon E3-1246v3 | RAM - 32GB (4x8GB) Samsung ECC | PSU - Enermax Revolution SFX 550W | Storage - 2x 512GB Samsung 860 Pro (System / "Fast" VM's), 4x 500GB HGST (RAID 10) | Case - Avid Unity MediArray XT (3U Rackmount) | OS - Windows Server 2019 Datacenter
Notebooks
Fujitsu Lifebook E756CPU - i5 6200U | RAM - 8GB DDR4 OEM | GPU - Intel HD 520  | Storage - 250GB Crucial MX500 | OS - Windows 10 Pro
Apple MacBook Pro Mid 2015 | CPU - i7 4770HQ | RAM - 16GB | GPU - Intel Iris Pro | Storage - 512GB Toshiba XG4 NVMe | OS - macOS 10.15.1
I don't want to hijack checkmates' thread, but I am in a similar situation.
I am looking for a nas and maybe I should go DIY. But I have no idea what hardware to use. A normal itx board? Or one with xeon embedded maybe? Dual socket? Discrete raid car or no? I only need a couple/few TB of storage, and it needs to be quiet and small, since it will have to be placed near our dining table or in my bedroom.
 Any suggestions?
My PC CPU: 2600K@4.5GHz 1.3v Cooler: Noctua NH-U12P SE2 MB: ASUS Maximus IV RAM: Kingston 1600MHz 8GB & Corsair 1600MHz 16GB GPU: 780Ti Storage: Samsung 850 Evo 500GB SSD, Samsung 830 256GB SSD, Kingston 128GB SSD, WD Black 1TB,WD Green 1TB. PSU: Corsair AX850 Case: CM HAF X. Optical drive: LG Bluray burner  MacBook Pro, Hackintosh
Basically it depends on your budget and usecase. If you want to use it just as an NAS, any fairly new Celeron board will do (or maybe something with an Pentium). If you want to run FreeNAS you need at least one GB of RAM for every TB you want to run but you don't need an discrete RAID card, FreeNAS is pure software RAID as well as unRAID etc. will be. I personally have an Parity Array on my Windows Server 2016 Machine but it's similar to the system unRAID uses.
I was in a similar situation because my NAS/Server needed to be silent as well. I have settled on BeQuiet parts for cooling and the only thing you can hear are the hard drives (which is fairly silent) - I am using WD Reds @5400 rpm.
If you want just PM me and I can give you further advice ;)
Main Rig
NAS / Docker Host
VM Host
Notebooks
Hope this helped ;)
RAID 5 isn't really an option for me since the jump in the price from 2-bay to 4-bay NAS enclosures are quite significant.
What exactly do you mean by you can do more with it? I only need the basic functionality such as:
  • Moving and copying files onto/from the disk
  • Playing videos from the devices in real time without copying onto local disk
Main Rig
NAS / Docker Host
VM Host
Notebooks
