Hi there,
I'd like to upgrade my existing PC with an custom waterloop. I put the parts of my existing PC with the new ones into this list:
https://de.pcpartpicker.com/list/czz2hq
What do you think? Is this sufficient or overkill? Did I made any mistakes?
I just want to make my PC as silent as possible while gaming in 1440p :)
I'm not sure if both radiators will fit properly into my desired case (Corsair 400C).
Does anyone have an existing custom waterloop in that case and can send me some pictures?
The budget should be below 1000 EUR.
If you need further information, please let me know.
Best regards
theLine
https://linustechtips.com/topic/857516-advice-for-first-custom-waterloop-x99/
The 280 won't fit:
Quote
Radiator Compatibility:
360 mm: front only
280 mm: front only
240 mm: front or top
120 mm: front, top or back
Not sure if a 240 would fit with the 360 in the front either.\
I would suggest one of these cases:
https://de.pcpartpicker.com/product/BKW9TW/corsair-case-750d
https://de.pcpartpicker.com/product/Wpfp99/fractal-design-case-fdcaarcxlblw
The Arc XL would need a 240mm in the front but the 360 definitely fits in the top.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
