Just now, Solid_Schmeckle said:
hello!
when I close my laptop and then open it again for a minutes my screen display becomes distorted any fix to this?? it happened 2 times now.
There cpuld be something wrong with the internal lvds connector for the screen.
Btw please use more descriptive titles in future
CPU: Ryzen 1700@3.9ghz; GPU: EVGA 560 Ti 1gb; RAM: 16gb 2x8 Corsair Vengeance LPX DDR4-3000; PCPP: https://pcpartpicker.com/list/b3xzzM
https://linustechtips.com/topic/857346-help/#findComment-10673919
2 minutes ago, Solid_Schmeckle said:
tnx for the reply. I'm going ask google now.
I'm sorry for the vague title
You may have to take it apart, as it is likely an issue of physical contact between the lvds connector and the mobo.
Its ok :)
https://linustechtips.com/topic/857346-help/#findComment-10673941
1 hour ago, Solid_Schmeckle said:
Is there a long term damage if i dont fix this problem?
No (assuming that it is a problem with the internal lvds connector contacting the motherboard)
https://linustechtips.com/topic/857346-help/#findComment-10674263
