7 minutes ago, CUDA_Cores said:
Are you increasing the voltage to your CPU? Many newbie overclockers don't do that and just increase the multiplier, and then wonder why their PC crashes at 5GHz at 1.1v.
Yeah, bump up your CPU voltage. But not past 1.35v, otherwise The CPUs longevity is reduced (so i've heard).
Is that all I need to do? Or can you give mea simple step by step here
https://linustechtips.com/topic/857205-overclocking-cpu-help/#findComment-10672449
1 hour ago, CUDA_Cores said:
I won't give you a step by step guide when there are many already available online. I suggest starting here:
https://lifehacker.com/a-beginners-introduction-to-overclocking-your-intel-pr-5580998
After doing some overlocks my cpu and motherboard can't even go 1.25v at 40. Is my cpu and motherboard not in great shape rn?
https://linustechtips.com/topic/857205-overclocking-cpu-help/#findComment-10672872
