I am have started building a budget gaming PC but I don't know what power supply to go with. I know you're not supposed to cheap-out on this part of the build but I would like to save as much money as possible and I don't really care about silent operation and other frills. I just want something that won't nuke my PC, is from a reputable manufacturer, has 6-pin PCIE power, and outputs around 400-500 watts.
My Specs are (or will be)
i5 4460
GTX 1060 6gb or RX 580 4gb (I haven't decided yet, probably whichever one I can get a deal on)
8gb RAM
2 Hard drives
2 case fans
I think the PC shouldn't draw much over 300 watts but I'm not sure, I'm pretty new to PC building. Thanks in advance for your response:)
https://linustechtips.com/topic/857015-power-supply-woes/
i5 4460
8gb RAM
2 Hard drives
2 case fans
The always cheap and available CX450 is a good choice.
https://linustechtips.com/topic/857015-power-supply-woes/#findComment-10670699
