Need help, wired slower than wireless.
7 minutes ago, KoeppColto024470 said:Power over Ethernet Networking (which is what I think you're using) slows down you're hard line speeds its better to have a hard line ran from your router or switch directly to your pc. Since it has to travel over power lines the signal degrades
Power over Ethernet (PoE) and Powerline are different technologies that perform different functions. Powerline uses power wiring to provide an ethernet connection and PoE uses an ethernet connection to provide power.
OP is using Powerline.
3 minutes ago, vong said:House was built in 2010 so wiring is still relatively new. Just odd that it started happening when I mentioned it.
Speeds for those interested:
Tablet - 3.27Mbps Down 1.23Mbps Up
Pc - 0.41Mbps Down 0.70Mbps Up
It's not all about how new the wiring is, how the house is wired and how much interference there is can affect speeds greatly. If it's only just started happening, you may need to either reset the powerline adaptors or find if something is creating a lot of interference.
