Corsair Lighting Node Pro not working like intended, think I know what the issue is
Solved by MGsubbie,
6 minutes ago, W-L said:Did you try swapping around the LED strips, might be an issue with the LED itself.
Turns out it must have been a faulty cable, or maybe I connected it the wrong way. I used a male to male cable from the LNP to the strip, now I used a male to female and it works. Thanks.
Featured Topics
xKempo ·
Posted in Troubleshooting0 -
3
Dcorrigan97 ·
Davidf4e ·
Posted in Troubleshooting1 -
3
2
3
Bobzcpu ·
Posted in Power Supplies2 -
2
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
