Hello, I am currently trying to upgrade my PC part by part. I don't know what to upgrade first. I have
two options, upgrade the CPU combo (highlighted in blue) or upgrade the GPU first. I know GTX 1080ti
is really an overkill for 1080p gaming but I really want to put my 144hz monitor to use as I dont have g-sync.
Also PUBG is one of the reason as currently my PC gets only 60-80FPS and it stutters and lags way too much,
with having 80FPS feeling like 50FPS and when it hits 60 FPS it feels like 20FPS, I know the game's optimization
is not perfect but I am sure the new PC build will perform better than this current one. Also the system has
been slightly damaged during transit so I might as well upgrade.
*note*
the cost of a GTX 1080ti is roughly equaled to a new Mobo + CPU combo + RAM here in Japan.
TL;DR
Want to upgrade new PC, CPU + Mobo first or GPU first?
4790k + GTX 980TI  ---> 4790k + GTX1080TI
then
4790k + GTX1080TI ---> 8700k +GTX 1080TI
                                 OR
4790k + GTX 980TI ---> 8700k + GTX 980TI
then
8700k + GTX 980TI ---> 8700k + GTX 1080TI
Current PC specs
i7 4790k
z97m Plus
16gb DDR3 1600 Corsair Vengeance
GTX 980TI
WD 1TB 7200rpm
Antec Truepower 750
Thermaltake Core P3 Snow edition (just upgraded)
Thermaltake Water 3.0 AIO (just upgraded)
New PC specs
i7 8700k
z370-e Strix
16GB DDR4 3200 TridentZ RGB
GTX 1080ti Strix
Samsung 850EVO 500gb
RM750W White edition
https://linustechtips.com/topic/855462-what-to-upgrade-first/
I would do the GPU first, your CPU is still good.
[Case] Phanteks Eclipse P400S TG (Air Mesh) || [CPU] Ryzen 7 5800X || [Cooler] Dark Rock Slim || [Mobo] ROG STRIX B550-F || [RAM] 32GB Trident Z RGB 3600MHz CL16
[GPU] XFX MERC319 Radeon RX 6950XT || [SSD] 1TB WD SN550 M.2 NVME || [HDD] 6TB Seagate IronWolf 7200 || [PSU] Corsair AX850
[Display] LG 27GL850 @ 2560x1440 - 144Hz || [Mouse] ROG Gladius II || [Keyboard] ROG Strix Flare (Cherry MX Red) || [Speakers] 2.1 Logitech Z-3 || [Fans] 6x 120mm Corsair LL RGB
Theater Room - My 11.1 Home Theater
https://linustechtips.com/topic/855462-what-to-upgrade-first/#findComment-10653723
*note*
TL;DR
then
                                 OR
then
Current PC specs
i7 4790k
z97m Plus
GTX 980TI
WD 1TB 7200rpm
Antec Truepower 750
New PC specs
i7 8700k
z370-e Strix
GTX 1080ti Strix
You could get good money for that 980ti if you sell it somewhere. I would go with the 1080ti and plus you get the destiny 2 bundle deal. Plus intel plans on releasing more cpus in a few months and that processor really isn't that outdated yet
https://linustechtips.com/topic/855462-what-to-upgrade-first/#findComment-10653775
