3 minutes ago, wONKEyeYEs said:
The Kraken X62 will fit in the PH-ES813P on the top or bottom, not front (240mm), or rear {120mm/140mm}.
GTX 1080s come in many sizes, which one?
You know the Kraken X62 takes 2x140mm fans?
So the kraken won't fit in the green case?
https://linustechtips.com/topic/855390-does-it-fit/#findComment-10652917
