Hi,
Did anyone came across a program that can wipe securely predefined folders. Something that has a list like Teamviewer and can be executed from outside the network.
The laptops run Windows 10 Pro with normal user and password not active directory.
Thank you!
https://linustechtips.com/topic/854238-remote-wipe/
I'd guess there is, what reason are you looking for this particular software?
https://linustechtips.com/topic/854238-remote-wipe/#findComment-10640203
47 minutes ago, GTM said:
Hi,
Thank you!
You can always write a script. Unless the user installed in not default folders, it would be relatively easy to find.
I'm assuming these are personal devices not Enterprise?
https://linustechtips.com/topic/854238-remote-wipe/#findComment-10640268
Its for a small business, and they want it for "just in case" someone leaves with a laptop. There are a lot of ifs, laptop has to be powered on, connected to the internet, the program running in the background.
Bad idea to start with, a company controlled cloud storage solution might be better.
https://linustechtips.com/topic/854238-remote-wipe/#findComment-10644943
