RGB help
Solved by JaegerB,
I'll assume you meant B350
Phanteks, NZXT, and a lot of other manufacturers make strips I that are Aura compatible.
You shouldn't need a control box, just a 1-3 splitter and some male-to-male 4 pin adapters, which you can get on amazon
Ozzi ·
Posted in Networking0 -
1
MadManMarsBar ·
Posted in Build Logs0 -
IAmAndre ·
Posted in New Builds and Planning3 -
4
2
Playgb2 ·
Posted in Troubleshooting1 -
2
1
5
play_circle_filled
Latest From ShortCircuit:
