I couldn't, but even if I did, I wouldn't help since CS forbids things like this.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/854147-help-with-cmd/#findComment-10639123
Nope. In the newer versions of windows they don't let this happen.
However, you can take a memory dump of RAM and then find the windows key then crack it using hashcat or John the Ripper on a separate system at a separate time.
ONLY DO THIS IF YOU OWN THE COMPUTER
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/854147-help-with-cmd/#findComment-10639131
Newer as in anything after Windows XP or newer as in Windows 10?
https://linustechtips.com/topic/854147-help-with-cmd/#findComment-10639136
Afaik after XP. Not sure about Vista, maybe even XP has it fixed, but for sure Windows 7 and up is where they get encrypted.
https://linustechtips.com/topic/854147-help-with-cmd/#findComment-10639146
via command prompt, no.
but Cain and Abel can tell you the password of every user on the computer.
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
https://linustechtips.com/topic/854147-help-with-cmd/#findComment-10639341
Just an update. Apparently in RAM the password is unencrypted. So that's that.
https://linustechtips.com/topic/854147-help-with-cmd/#findComment-10641935
13 hours ago, L.Lawliet said:
Cracked my first wifi password when i was 12 using that..handy tool i must say if u know how to use it..
i still use it occasionally.
got a laptop from a pawn shop that hadnt been wiped.
created a new admin from a boot disk, used cain &abel to get the password of the other users, logged in, pull all the data from it and let the previous owners know the pawn shop didnt wipe it like they said they did, and somebody more of a dick than me coulda just stolen their identity lol
|Specs in profile|
https://linustechtips.com/topic/854147-help-with-cmd/#findComment-10643460
