hello
i am trying to get my tv display to work as my third display with no results
currently i have display 1 and 2 plugged in hdmi to my graphics card (asus gtx 1070)
because i only have more extra hdmi cables and not display cables i connected the third disaplay to the actual mother board hdmi slot and it seems it is not receiving anything.
https://linustechtips.com/topic/854025-help-getting-third-display-to-work/
1 minute ago, Nipplemilk909 said:
hello
The motherboard HDMI slot is not useful unless your CPU has onboard enabled graphics. Same applies to the motherboard. Use a DP to HDMI
i would buy a converter and plug it into your gpu that will be ur best and easiest solution
main system build --> i7-7700K (at 5.0 ghz), MSI Z270 SLI Motherboard, corsair vengeance lpx 8gb ddr4 2666mhz,  costume liquid cooling loop with 360 mm radiator on CPU, GTX 1080 gigabyte windforce OC, 1TB WD drive, 128 gb samsung nvme m.2, EVGA 850 watt semi modular power supply, CM storm stryker case (ya not ideal for costume loop), VIOTEK GN34C 34 inch curved monitor <----
We are told to remember the idea, not the man, because a man can fail. He can be caught, he can be killed and forgotten, but 400 years later, an idea can still change the world."
You're going to need to use your GPU, unless your CPU and BIOS support using the iGPU and a dGPU at the same time. Just grab a cheap adapter.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
