Ok i wonder what other part's i need to complete a atx/sff build these are the part's i have
SFF/MT form factor AMD socket AM2 HP DC5700/ I seen can fit a MT form factor as well
CPU:AMD Phenom x4 Quad Core 2.3ghz CPU
RAM: 2x 1GB DDR2 Dimm (Samsung) 512Mhz memory speed and x2 4GB DDR2 Dimm (Sochox) 667Mhz memory speed
HDD: 2x WD Barracuda 7200RPM (1x80 1x500)GB
Optical Drive: DVD Rom HP Compact Disc RW ultra speed
GPU: AMD ATI Radion HD 6450 1GB V-Ram PCI-E  x16
PSU: Delta Electronics 50-60hz 250watt max SATA PSU
Other wires/connections: 3x SATA wires,HP DC5700 power switch, HP DC5700 CPU fan, DVI to VGA video adapter, 4x CMOS battery's, PSU Power Cable, HP DC5700 socket 775 HeatSink, Vastech Brush-less fan (RGB)
Other NOT included Parts/ And are for sell if wanted: 2x Nanya 512MB DDR2 DIMM 667Mhz memory speed, 1x HP MT 1GB DDR2 DIMM 667Mhz memory speed, Intel Core 2 Duo 6300 SLASE MALAY 1.8Ghz 2MB/L2 06' socket 775,
Intel Pentium 4 SL96J 3.4Ghz 2MB/L2 05'socket 775, Intel Celeron SL9XP 1.6Ghz 512MB/L2 06' socket 775, 1x Hynix 1GB DDR2 So-Dimm 555mhz memory speed, HP Realtek wi-fi laptop card, 1x Samsung 1GB So-Dimm 555mhz memory speed, 1x Transcend 2GB DDR2 So-Dimm 667Mhz memory speed, 1x WD Scorpio Blue 160GB SATA Laptop HDD, 1x Acer Laptop Battery (unknown cell amount) (model#AS09A31), 1x PNY Nvidia Quadro NVS290 and that's it
https://linustechtips.com/topic/854014-home-pc-build/
