3.9" Card Reader mount
Go to solution Solved by Dr3nz4r,
sure you didnt mean 3.5"?
if so, take a look at: http://www.bitfenix.com/global/en/products/accessories/525-drive-bay-adapter/
Hi,
Does anyone know if its possible to mount a 3.9" Card reader (that i pulled of of my old Dell) and mount it onto a disk drive bay on my Corsair 300r.
What i need really is some sort of mounting adapter that fits nicely into a disk drive slot, but can be used to hold a 3.9" (10cm) drive and fill up the gap so dust and air wont get in.
> The Card reader does actually fit into a HDD mounting tray, but that would be very inconvenient being inside the case.
https://linustechtips.com/topic/85401-39-card-reader-mount/
CPU: Intel i7 4790K @4.8GhZ  CPU Cooler: Be Quiet! Dark Rock Pro 2  Motherboard: Gigabyte Z97 UD3H  GPU: Asus ROG RX 480 8G OC Memory: 32GB Gskill Ares 2400Mhz  Storage: 2x Crucial M4 512GB SSD (raid0)  / 1TB Seagate FireCuda SSHD Case: Phanteks Enthoo Evolv ATX PSU: EVGA SuperNOVA P2 750W  Operating System: Windows 10 Enterprise LTSB (64 bit) Other: NZXT Hue+ LED Controller with 8 LED Strips for desk and PC lighting
https://linustechtips.com/topic/85401-39-card-reader-mount/#findComment-1161033
3.9" ? That's a first.
In the grim darkness of the far future, there is only a GTX 1080, just a single 1080, where my glorious PC once stood....
For that is all I need, For the Emperor of Man, Jen-Hsun Huang, protects. We march for Nvidia, and we shall know no fear!
https://linustechtips.com/topic/85401-39-card-reader-mount/#findComment-1161044
Also you said it fits in a hhd caddy so iits most likely the standard 3.5" card reader and there are lots of adapter for that like the one Dr3nz4r linked.
https://linustechtips.com/topic/85401-39-card-reader-mount/#findComment-1161052
