Hi guys.
Last year around January I pieced together a beautiful little rig, and it's been incredible. This thing eats 1080p alive (at least for the titles I play) and works tremendously well. However, this year I'm considering some small upgrades to help the computer work better and look cooler. With more breathing room this year, I can now go all out on refining this rig.
First of all, I need to make sure my rig is well-cooled. Although my Corsair H50 works great, the GPU gets stupid hot under load (around 82*C at peak temps), sometimes resulting in a crash. I believe this is a result of a lack of fans to cool down the rest of the system. (I have one 120mm Cooler Master fan blowing into the top, but that's all). What are the best 140mm fans around? I'd like to keep the blue theme going as strong as possible too.
Secondly, I could use an SSD. I currently use a 1TB Seagate hard drive, and it works reasonably well and fast compared to any console I've ever owned. However, I could totally go for faster. I'm considering the Samsung 850 EVO 500GB, as the 850 series is widely considered the best on the market. However, it's pricey at $150. Is it worth that price?
Since it wouldn't be awfully more expensive, I'm considering an upgrade to Windows 10 since I still have Windows 7. Is that upgrade worth bothering with? Will I be gaining anything other than a longer lifespan for the OS?
Lastly, I'm considering some flair for my case. I'd like to light my case up blue to match the rest of my setup. Does anyone have suggestions for good lights or light controllers? (I do not have any drive bays on my case, so some may not work)
Any other suggestions (keyboards as mine is getting old, monitors, comfort of life upgrades, etc.) are welcome!
Thanks for all the help guys! Have an awesome day/night!
H A L C Y O N
Specs:
CPU: Intel Core i5-4690K @ 3.5GHz
CPU Cooler: Corsair H50
Motherboard: ASRock Z97 Anniversary
GPU: MSI RX 480 Gaming X 8GB
RAM: G.Skill Ripjaws X 16GB (2x8GB) DDR3-2400
HDD: Seagate Barracuda 1TB 7200RPM
Power Supply: SeaSonic G-Series 550W
Case: NZXT S340 (black/blue)
Peripherals:
Monitor: BenQ RL2455HM
Keyboard: Logitech G810 Orion Spectrum
Mouse: Logitech G502 Proteus Spectrum
Headset: Logitech G633 Artemis Spectrum
Mousepad: HyperX Fury S XL
https://linustechtips.com/topic/853177-holiday-upgrade-advice/
850 is worth that money, being the fastest SATA SSD out there.
You can upgrade to Windows 10 for free. Link to guide. It's from Microsoft itself so dont worry. A bit of a loophole since it's not intended for the general user though :P
Desktop benching:
https://linustechtips.com/topic/853177-holiday-upgrade-advice/#findComment-10628183
The 850 is worth it. Definitely.
In terms of the cooling, perhaps 3 blue corsair AF140/SP140s or something similar blowing in the front, and one top one back pulling out. I believe phanteks and cablemod make pretty good LED strips, and the NZXT hue is a decent controller, although there are others on the market.
Hope it helped,
Jaeger
HEADS UP, THIS ACCOUNT IS INACTIVE NOW
I'm keeping everything else the way it was for anyone who might check out my answers in future, but I won't be using LTT.
Don't forget to quote me when replying to me!
Please explain your question fully, so I can answer it fully.
PSU Tier List Cooler Tier List SSD Tier List  My Specs Below!
My PC:
CPU: Ryzen 5 1600 @ 3.2GHz
Cooler: Stock Wraith Spire
RAM: G.Skill Trident Z RGB 3000mHz 16GB DDR4 (2x8GB) RGB
Motherboard: Asus ROG Strix X370-F Gaming ATX
SSD: Crucial MX500 500GB 2.5"
HDD: Western Digital Blue 1TB 7200rpm
GPU: Asus ROG Strix OC GTX 1060 6GB
Case: Cooler Master H500P
PSU: Corsair RM650i 650W 80+ Gold Fully Modular
OS: Windows 10 Home 64-bit
Fans: 4x Cooler Master Masterfan Pro 120 Air Balance
Potato Laptop (Samsung Series 5 Ultrabook, 2013):
CPU: Intel Ivy Bridge i5 3337U @ 1.8GHz
RAM: 8GB DDR3 2133mhz SODIMM (1x4GB Samsung, 1x4GB Kingston)
SSD: Kingston 24GB SSD (originally for caching)
HDD: HGST 500GB 5400rpm
GPU: Intel HD 4000 Graphics
https://linustechtips.com/topic/853177-holiday-upgrade-advice/#findComment-10628192
