So I am overclocking yesterday's flagship. The GTX+ 9800 512mb and I was wondering does anyone still remember any settings that I can just punch in to overclock my card?
#KilledMyWife
LTT's Resident Black Star
I should get an award for still being here at this point
https://linustechtips.com/topic/85240-old-beast-overclocking-help/
Switch it to Wumbo.
Motherboard - Gigabyte P67A-UD5 Processor - Intel Core i7-2600K RAM - G.Skill Ripjaws @1600 8GB Graphics Cards  - MSI and EVGA GeForce GTX 580 SLI PSU - Cooler Master Silent Pro 1,000w SSD - OCZ Vertex 3 120GB x2 HDD - WD Caviar Black 1TB Case - Corsair Obsidian 600D Audio - Asus Xonar DG
   Hail Sithis!
I laughed for 3 minutes straight when I heard this...
:P Glad you liked it.
   Hail Sithis!
Every card is different.
Just punched in 751, from 738 and will see if stable. if it is I will be quite happy with the extra 1 fps
#KilledMyWife
9800 GTX+.....ohhh those days...Radeon HD 4850 vs 9800GTX+ days :)
If you are just plugging in random values and hoping they will work....you are doing it wrong.
In fact, if you do it to any of the newer CPU or GPUs...probably not going to work. No two chips are 100% identical.
Somebody...say...Todd's 9800GTX+ can get 900MHz/1200MHz....while Bob Doe's 9800GTX+ can only get 850MHz/1150MHz...then poor Stan here only get 810MHz/1100MHz (not too much from stock).
But....from what I recall, around 800MHz on the core and 1200MHz on the memory was pretty much guaranteed. Not too sure about the Shader clock, though.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
thanks for the advice, I know that every card is different but there are certain minor overclocks that are guaranteed
#KilledMyWife
Ok, guys so I got her up to 800 core and 1100 mem stable in afterburner. I got 15 extra fps and extended the usefulness of this card for the rest of my crap gpu challenge.
#KilledMyWife
Push it even MOAR!!
Try adjusting the Shader clock now :P
Anyways, I've seen quite a bit with 820 / 830 / 850MHz on the Core...and 1200 / 1220 - 1250MHz on the Memory.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
Push it even MOAR!!
this thing just keeps overclocking lol, now its at 815! I am gonna bump up the memory now
#KilledMyWife
Ahh yes, had them both in 512 meg variants. The 9800gtx+ kicked 4850's ass all over the place.
Intel 4770k@4.6GHz, ASUS ROG Maximus VI Hero, Kingston HyperX Beast 2x8GB 2400MHz CL11, Gigabyte GTX 1070 Gaming, Kingston HyperX 3k 240GB - RAID0 (2x120Gb), 2xWD 1TB (Blue and Green), Corsair H100i, Corsair AX860, CoolerMaster HAF X, ASUS STRIX Tactic pro, Logitech G400S, HyperX Cloud II, Logitech X530, Acer Predator X34.
Ok guys so I made video about overclocking it, its not stable at 850 but was wondering if I were to overvolt the gpu would it maybe be stable?
#KilledMyWife
