I I'm currently looking to update my drivers, and I've tried to do it multiple times. I own a RX 480 amd gpu, and have constantly tried to update it to the version 17.10.3. But every time I look under the driving packaging version in the AMD Radeon settings, it sais it's 16.30.2311, not my driver version I'm looking for. I'm doing this all to play the new game Wolfenstein: The New Colossus, and its so frustrating not being able to play. Can anyone help me to download these drivers correctly?
https://linustechtips.com/topic/852194-gpu-driver-help/
Eii another fellow wolfenstein player in trouble...this is just annoying! Are you having the issue with the "could not wire crash dump" error?
MAIN RIG | AMD R7 1800x @ 4.0GHz [cooled by Corsair h110i] | Zotac 1070 founders | Corsair Dominator Platinum 2x8gb |
| ASUS crosshair IV hero | Samsung 960 evo m.2 | Seagate 1TB + WD blue 2TB| Corsair HX750i | Phanteks evlov atx TG |
LAPTOP | HP zbook Workstation | Intel i7-4710 HQ @ 2.5GHz | 8gb ram | NVIDIA Quadro k1100m | 250gb + 250gb Crucial SSDs |
https://linustechtips.com/topic/852194-gpu-driver-help/#findComment-10618410
Exactly what i'm having, i've tried everything, updating drivers, disabling onboard integrated graphics, deleting my gpu and reinstalling software. Nothing works, I just want to play!
https://linustechtips.com/topic/852194-gpu-driver-help/#findComment-10618426
Same here, we just need to wait for a patch/ specific driver update (apparently both might be coming next week)
https://linustechtips.com/topic/852194-gpu-driver-help/#findComment-10618437
9 minutes ago, Himommies said:
DDU the driver and just reinstall it.
I would also wait a week or two to play Wolfenstein as it's not to enjoyable for me right now with all the crashes and whatnot
How would you suggest uninstalling the driver then? Because i've already tried going into devices, clicking display, and uninstalling the drivers for the gpu, then reinstalled them. Could you provide me with a walkthrough or a quick explanation?
https://linustechtips.com/topic/852194-gpu-driver-help/#findComment-10618438
DDU
My life
https://linustechtips.com/topic/852194-gpu-driver-help/#findComment-10618443
2 minutes ago, TechyNoob said:
Is it a download or something? I've looked on google and it seems to be a download, though I can't find any trustworthy links? Do you have one at all?
http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
My life
https://linustechtips.com/topic/852194-gpu-driver-help/#findComment-10618457
