Hi, just wanting to check that this build works
Gigabyte Nvidia GTX 1050Ti WF2 OC 4GB GDDR5 PCI-E £150.97
Corsair CMK16GX4M2B3000C15 Vengeance LPX 16 GB (2x8 GB) DDR4 3000 MHz C15 XMP 2.0 High Performance Desktop Memory Kit - Black £170.15
Asus Prime B350-PLUS AMD DDR4 S-ATA 600 ATX Motherboard - Black £75.44
Seagate BarraCuda 2 TB 3.5 inch Internal Hard Drive (64 MB Cache SATA 6 GB/s up to 210 MB/s) £61.86
Corsair CP-9020098-UK VS Series ATX/EPS 80 PLUS Power Supply Unit, 650 W £47.05
AMD Ryzen 5 1600 Desktop CPU - AM4/Hex Core/GHz/16MB/65W £178.50
CiT Dragon 3 Midi Case with 12 cm Red LED Fans and Side Window - Black £33.48
Overall cost: £701.07
https://linustechtips.com/topic/851967-my-first-build/
From a glance, it looks to be fine, but I would invest into an SSD boot drive to makes Windows and general computing a much more pleasant experience.
Build goes here :) :
CPU: Core i7-5960X                        Storage: 500GB Crucial MX200                      Case: Corsair 760T (White)
Mobo: ASUS X99 Deluxe II                             3TB Seagate Barracuda                   PSU: Corsair AX1200i
RAM: 32GB G.Skill TridentZ RGB                   6TB WD Red                                     Other stuff goes here :)
GPU: Nvidia TITAN X (Pascal)                         1.2TB Intel 750 series PCIe SSD      Other stuff goes here :)
https://linustechtips.com/topic/851967-my-first-build/#findComment-10616200
1 minute ago, Zucchini said:
Looks good to me. Would a GTX 1060 3gb be better bang for the buck though?
AHHHHHHHHHHHHHHHHHH 3GB version is really really really bullshit 6GB costs like 30 bucks more and has double the memory which makes it a lot more future proof.
https://linustechtips.com/topic/851967-my-first-build/#findComment-10616232
get a better psu, the VS is very low quality. a 400w pure power 10 is around the same price and much better.
https://linustechtips.com/topic/851967-my-first-build/#findComment-10616755
I'd recommend this:
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  (£178.50 @ Amazon UK)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  (£71.24 @ Amazon UK)
Memory: Crucial - 8GB (1 x 8GB) DDR4-2133 Memory  (£66.26 @ Alza)
Storage: Plextor - M7V 128GB 2.5" Solid State Drive  (£47.45 @ Ebuyer)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  (£36.50 @ Aria PC)
Video Card: Zotac - GeForce GTX 1060 6GB 6GB Mini Video Card  (£239.99 @ Ebuyer)
Power Supply: be quiet! - Pure Power 10 400W 80+ Silver Certified ATX Power Supply  (£42.55 @ Aria PC)
Other: ARIANET CIT-F3WHITEBLACK  (£21.95 @ Aria PC)
Total: £704.44
Generated by PCPartPicker 2017-10-28 16:28 BST+0100
https://linustechtips.com/topic/851967-my-first-build/#findComment-10618425
1 hour ago, Andrew stev said:
might consider it. am having my friends who have built before helping me so will get their opinion as well
IF you consider it PLEASE PLEASE don`t buy the 3GB version i don`t even know why this card exists go for  the 6 GB version.
https://linustechtips.com/topic/851967-my-first-build/#findComment-10618592
