Is this enough power?
Go to solution Solved by dual290x,
I agree with @ZeusXI. You have plenty to work with. Go with a 4tb. That way you won't have to go out and buy another down the road. It will last longer in terms of capacity.
My current pc spec is
i5-6500
16gb ddr4 2133mhz
ga b150m-ds3h
gtx 1060 6gb gigabyte
crucial mx300 275 gb ssd
wd blue 1tb hdd
cx450m psu
I'm currently in school broadcast class and I got tired of editing on DUAL CORE MAC so I brought video clips to home and my 1 tb hard drive is full due to games
Do you guys think I can add 2tb hard drive to my pc?
I think my pc uses about 320 watt max under load....
https://linustechtips.com/topic/850810-is-this-enough-power/
Easily... the extra hard drive won't consume an appreciable amount of power.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/850810-is-this-enough-power/#findComment-10603663
i5-6500
16gb ddr4 2133mhz
ga b150m-ds3h
wd blue 1tb hdd
cx450m psu
with your cpu being 65W, GPU 120W, and, you could add a bunch more hdd or ssd
https://linustechtips.com/topic/850810-is-this-enough-power/#findComment-10603670
Instructions for frustration management:
1) Sit at desk.   2) Repeatedly slam forehead against desk.
I never said I was smart, just smart enough to be dangerous.
ORLY?
……..'|:::::::,': : : : : : :_„„-: : : : : : : : ~--„_: |'
………|::::::|: : : „--~~'''~~''''''''-„…_..„~''''''''''''¯|
………|:::::,':_„„-|: : :_„---~: : :|''¯¯''''|: ~---„_: ||
……..,~-,_/'': : : |:    ͡° ͜ʖ ͡°) : |: : : :|:  ( ͡° ͜ʖ ͡°)): \..|
……../,'-,: : : : : ''-,_______,-'': : : : ''-„_____|
………',:': : : : : : : : : : : : :,-'__: : : :_',: : : : ;: ,'
……….'-,-': : : : : :___„-: : :'': : ¯''~~'': ': : ~--|'
………….'|: \: : : : : : : : -,„_„„-~~--~--„_: :: |
You have been visited by the propane god, I tell ya hwat. Repost this on 5 more profiles or Hank Hill will bring the propain.
- credit to, @Cinnabar Sonar
https://linustechtips.com/topic/850810-is-this-enough-power/#findComment-10603676
i5-6500
16gb ddr4 2133mhz
ga b150m-ds3h
wd blue 1tb hdd
cx450m psu
That system might consume 200W if you pushed it. You're fine adding as many hard drives as your board supports.
https://linustechtips.com/topic/850810-is-this-enough-power/#findComment-10603730
