Hi there,
I am considering to buy GTX 1080ti for my existing machine. Currently I have a 2GB GTX 680, and it has been really good and keeping up with most of the tasks.
Question: I am looking online and there are cards with different base clock speeds, which, I understand the higher - the faster performance. However, how much of a difference does it make when modeling heavy 3D scenes (dense in geometry/shading)?
Also, does it have any effect on CUDA rendering (speed)?
As always, thanks to everyone.
https://linustechtips.com/topic/849373-boost-clock-for-3d-modeling-cuda-rendering/
no difference with the base clocks at all,they all boost into the 1900's anyways
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
4 hours ago, nowikovs12 said:
Hi there,
Long Answer:
to answer this in a professional way we should know how the algorithm works and take a few hints on how it scales.
Usually clock increments scales linearly, assuming there is no bottleneck elsewhere. This assumption is quite expensive in terms of giving a proper answer. The particular software modeling you are using with the particular flags you are using could be in a resource shortage elsewhere, before it hits the max clock roof. ie: VRAM. Hence you'd see no performane boost (which is totally the case in most mainstream GPUs with pro-hardware since, clock favors rapid data output burst, while rendering pro software prefer accuracy.
M
Short Answer: Doesn't matter much since you can overclock any 1080Ti to reach within 5% any other 1080Ti clock level.
