Ok, rather simple question but I know very little about TVs or how the brackets needed to mount them.
I would like a bracket that will bolt into the wall on the blue part to the left of the TV and allow me to have my TV over the top of my desk.
The TV I have is 40’ and made by JVC, if any other info is needed I’ll do my best to provide.
Thanks in advance,
Have a nice day, James
CPU: R5 3600 @ 4.4 GHz
RAM: 16GB DDR4 @ 3200 MHz
GPU: RTX 2080 Super
https://linustechtips.com/topic/849232-how-to-mount/
On 22/10/2017 at 2:55 AM, Kaelen said:
That is a bit complicated. The best way to go about that is an articulating mount. But that still wont get it directly over the desk. Is there a reason as to why you cant mount it over the desk?
Quite a fragile dry wall where as the left wall is brick.
GPU: RTX 2080 Super
https://linustechtips.com/topic/849232-how-to-mount/#findComment-10600346
