Need help with mic problem!
Go to solution Solved by Vandorlot,
Look on the bottom left thats what mine looks like. It may be diffrent since you got a diffrent mobo
Just now, Jto13 said:
Hi i have a pair of hyper x cloud revolver headphones, problem is i can hear myself through my headset, i have listen to device off and when i go into playback> levels the mic option isn't there  it just started today
im using discord if that has anything to do with it but it just started today didn't do it yesterday
Look in your audio driver settings.
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
wheres that?
Check your toolbar on the bottom left.
My Rig
 Peripherals
My Rig
 Peripherals
