Hello guys i am looking for a LapTop that will be used mainly for school (Word, Excel, Powerpoint) from time to time (AutoCAD, Solidworks), for work (Photoshop, Illustrator, SonyVegas or Premiere) and rarely for gaming. I am looking at this one: HP Omen 15-ce013nu, 2LF21EA, 15.6", Intel Core i7 Quad-Core. The specs are:
CPU - i7 ; GPU - 1050ti 4GB ; RAM - 16gb @ 2400MHz ; HDD - 1000GB and SSD - 256GB
Here is a link from a Bulgarian site: https://www.jmt.bg/hp-omen-15-ce013nu-2lf21ea-pid25209 it costs areound 1300$ tell me is it good and is it worth it! :)
https://linustechtips.com/topic/848675-laptop-help/
I do not think that computer would be a really good value because there are similar laptops with similar specs that are priced a lot lower. I would recommend the computer that I will provide a link to or otherwise, some Alienware laptop might be a good option also.
Link to the computer that I would personally recommend based on the applications that you will be running on the computer:   https://www.bestbuy.com/site/dell-inspiron-15-6-touch-screen-laptop-intel-core-i3-8gb-memory-1tb-hard-drive-black/5835852.p?skuId=5835852
Hope this information post was helpful  ?,
        @Boomwebsearch
https://linustechtips.com/topic/848675-laptop-help/#findComment-10580821
