Hey guys, so my dog chewed up the plastic on a USB stick while I was gone. I was able to pull the whole board out, and it doesn't seem to be broken in any way. When I plug it into a USB port, the light on the stick comes on and Windows dings every time you plug it in or unplug it with the usual USB sound, however no drive shows up in explorer or disk management.
Can you guys think of anything else to try to save it?
https://linustechtips.com/topic/847988-usb-stick-damaged/
Disk management/partition manager
Join the Appleitionist cause! See spoiler below for answers to common questions that shouldn't be common!
Q: Do I have a virus?!
A: If you didn't click a sketchy email, haven't left your computer physically open to attack, haven't downloaded anything sketchy/free, know that your software hasn't been exploited in a new hack, then the answer is: probably not.
Q: What email/VPN should I use?
A: Proton mail and VPN are the best for email and VPNs respectively. (They're free in a good way)
Q: How can I stay anonymous on the (deep/dark) webzz???....
A: By learning how to de-anonymize everyone else; if you can do that, then you know what to do for yourself.
Q: What Linux distro is best for x y z?
A: Lubuntu for things with little processing power, Ubuntu for normal PCs, and if you need to do anything else then it's best if you do the research yourself.
Q: Why is my Linux giving me x y z error?
A: Have you not googled it? Are you sure StackOverflow doesn't have an answer? Does the error tell you what's wrong? If the answer is no to all of those, message me.
https://linustechtips.com/topic/847988-usb-stick-damaged/#findComment-10573068
31 minutes ago, ShadowWolf810 said:
Oops missed that, sorry
https://linustechtips.com/topic/847988-usb-stick-damaged/#findComment-10573130
3 minutes ago, ShadowWolf810 said:
You're good, I can't really think of anything else to try. It seems to be functioning and recognized by Windows, but the drive isn't showing up :/
Try it on another OS and/or with a deeper tool like gparted
https://linustechtips.com/topic/847988-usb-stick-damaged/#findComment-10573145
7 minutes ago, ShadowWolf810 said:
So tried it on Linux, comes up as Phison 2307 PRAM.... But I can't format it or anything... Hmm.
A root privileged gparted couldn't do anything?
https://linustechtips.com/topic/847988-usb-stick-damaged/#findComment-10573197
No it shows up as "No Media" according to google it means that the connection between the memory controller and the storage isn't working. Tried a couple things but it might just be dead unfortunately. You can see it in Diskpart, but it gives an error if you try to create a partition on it
https://linustechtips.com/topic/847988-usb-stick-damaged/#findComment-10573226
