Graphics card not working
Go to solution Solved by mtz_federico,
1 minute ago, mtz_federico said:
i am trying right now my radeon hd 6870 on the main x16 PCIe slot
and apparently yup dead gpu
So in may of 2015 I built a computer for the first time the specs are:
Motherboard: Asus ROG Maximus Hero VII
CPU: Intel I5 4440
Storage: WD 1 TB Blue
GPU: originally AMD Radeon HD something, now AMD Saphire RX 280
Power Supply: Cooler Master V650
on August 21 of this year (2017) i was cleaning my pc and I saw that the Intel cooler clips on my cooler master something cooler were not properly attached so I tried to put them correctly but they just broke so I bought a new cooler (the cooler master hyper T4) and it was all running fine for about a week until one day I was mining etherium and when I tried to use the computer nothing would happen not even when I tried to turn it off using the power button, then i couldn't even get the computer to post after a few days of trying to fix it I got it to post using the internal Intel graphics and now it only works with the integrated graphics
does anybody have this problem, had it, or know how to fix it?
https://linustechtips.com/topic/847941-graphics-card-not-working/
Sounds almost like a dead GPU. Do you still have the Radeon HD card to test it with?
