1 minute ago, Darkdestroyer445 said:
So I'm not home to try anything at the moment BUT I got a Asus Socket FM2+ A88XX and I have 12gb of ddr3 ram installed, a GTX 1050 ti and a x4 860k in it but Everytime I press the power button, it comes on but never displays anything. Please help.
Confirm no power or data connections have been jarred loose and clear the CMOS. Make sure your cards and RAM are seated correctly.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/847886-help/#findComment-10571873
This,
Also make sure the PSU is turned on
https://linustechtips.com/topic/847886-help/#findComment-10571883
Just now, Crunchy Dragon said:
This,
Ah yes, can't forget the typical IT desk response. xD Though he says it does light up so I guess it's safe to assume it is turned on.
https://linustechtips.com/topic/847886-help/#findComment-10571888
Oh true lol. I'm looking at going into IT so I'm working on the responses(jk)
That was the first mistake I made in my build though so I tend to recommend it where I can
https://linustechtips.com/topic/847886-help/#findComment-10571890
Same. My first response here used to always be ...
AAEAAQAAAAAAAAdbAAAAJDNlZWVmOWY4LTY2MmUt
https://linustechtips.com/topic/847886-help/#findComment-10571905
Can confirm. I don't say it in Roy's voice, but I do have to ask that on occasion.
CPU: Core i7 4970K | MOBO: Asus Z87 Pro | RAM: 32GBs of G.Skill Ares 1866 | GPU: MSI GAMING X GTX 1070 | STOR: 2 X Crucial BX100 250GB, 2 x WD Blk 1TB (mirror),WD Blk 500GB | CASE: Cooler Master HAF 932 Advanced | PSU: EVGA SUPERNOVA G2 750W | COOL: Cooler Master Hyper T4 | DISP: 21" 1080P POS | KB: MS Keyboard | MAU5: Redragon NEMEANLION | MIC: Snowball Blue | OS: Win 8.1 Pro x64, (Working on Arch for dual boot) |
https://linustechtips.com/topic/847886-help/#findComment-10571918
16 hours ago, Darkdestroyer445 said:
Would it be that I have to update BIOS for some reason?
Did you follow the previously mentioned suggestions already? Do you have a PC speaker connected to the speaker motherboard header?  Is it a new build or did it work and suddenly stop working?
https://linustechtips.com/topic/847886-help/#findComment-10574944
No I do not. And it's a new build.
https://linustechtips.com/topic/847886-help/#findComment-10578806
I would get a PC speaker that connects to the header on your motherboard. They're usually $5 or so. It can produce beep error codes on bootup, which will help you narrow down what your issue is more effectively. Most motherboard manuals have a section for beep codes and what they relate to.
https://linustechtips.com/topic/847886-help/#findComment-10579164
