Overclocking help
Solved by Max_Settings,
RAM speed can only be changed in the BIOS. And overclocking RAM won't kill it, and I hoped you have went and changed the RAM speed in your BIOS especially since you have Ryzen because RAM doesn't run at advertised speed by default you have to manually set it in the BIOS. Now VRAM speed can be changed using Afterburner and that is also safe. You won't kill your GPU overclocking, it is nearly impossible.
