I have this cheap case:
in the white version it's easy to see in the front the only ventilation, those 2 black strips on the side (there is nothing in the top or bottom for the air to get in) protected with a mesh. Is this enough? should i just go DiY on it and make some holes and put a mesh in the front? as a n00b i cannot see how the front fans can get fresh air with just those small "meshed" strips
https://linustechtips.com/topic/847224-case-modding-or-not/
Depends what you're putting in it. I'm guessing you aren't loading it full of GPUs and other high heat components, so that will be enough. 2 fans in, one out will be enough for airflow. If you're really worried or your temps turn out to be high, that case has a top fan bracket so you could even install a third pulling in.
HEADS UP, THIS ACCOUNT IS INACTIVE NOW
I'm keeping everything else the way it was for anyone who might check out my answers in future, but I won't be using LTT.
Don't forget to quote me when replying to me!
Please explain your question fully, so I can answer it fully.
PSU Tier List Cooler Tier List SSD Tier List  My Specs Below!
My PC:
CPU: Ryzen 5 1600 @ 3.2GHz
Cooler: Stock Wraith Spire
RAM: G.Skill Trident Z RGB 3000mHz 16GB DDR4 (2x8GB) RGB
Motherboard: Asus ROG Strix X370-F Gaming ATX
SSD: Crucial MX500 500GB 2.5"
HDD: Western Digital Blue 1TB 7200rpm
GPU: Asus ROG Strix OC GTX 1060 6GB
Case: Cooler Master H500P
PSU: Corsair RM650i 650W 80+ Gold Fully Modular
OS: Windows 10 Home 64-bit
Fans: 4x Cooler Master Masterfan Pro 120 Air Balance
Potato Laptop (Samsung Series 5 Ultrabook, 2013):
CPU: Intel Ivy Bridge i5 3337U @ 1.8GHz
RAM: 8GB DDR3 2133mhz SODIMM (1x4GB Samsung, 1x4GB Kingston)
SSD: Kingston 24GB SSD (originally for caching)
HDD: HGST 500GB 5400rpm
GPU: Intel HD 4000 Graphics
https://linustechtips.com/topic/847224-case-modding-or-not/#findComment-10564269
2 minutes ago, asus killer said:
no, it's just a rx 470 and an i5 non OC. thanks will leave it as is then. I only have a front and a rear fan, will put one more in the front then.
move the rear fan to the front
https://linustechtips.com/topic/847224-case-modding-or-not/#findComment-10564287
Just now, asus killer said:
a fan is cheap, i don´t mind buying one.
You suggest i leave the back without fans? would that not be worst?
should give positive pressure and help keep dust out
https://linustechtips.com/topic/847224-case-modding-or-not/#findComment-10564325
