Please, im desperate, I just build my first pc like 3 weeks ago, but cant figure out for the life of me why do I keep getting static through my tv speakers
pc, https://pcpartpicker.com/list/jpfPZ8
already tried all this https://helpdeskgeek.com/windows-7/fix-audio-staticcracklingpopping-with-realtek-sound-card/
uninstalled realtek drivers and its only the vega drivers for audio
https://linustechtips.com/topic/845532-help-static-audio/
Is it actually static? Or is it like EMI? If it's the later, there's little you can do.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/845532-help-static-audio/#findComment-10546686
Do you mean built in tv speaker? Or do you mean speakers connected to tv? Does tv receive audio through hdmi? Does tv make staticy sound using other sources? Have you tried another hdmi cable?
Specs: Amd 1700x | NH-u12s | Asus crosshair hero vi | 2x8g Gskill flare x | Zotac 1080 | Samsung 960 EVO | Seasonic ssr-750GD | Thermaltake core x5 |
https://linustechtips.com/topic/845532-help-static-audio/#findComment-10547502
Tv built in speaker through hdmi, tried another cable the same, when i use my headphones is the same but not equally bad
https://linustechtips.com/topic/845532-help-static-audio/#findComment-10547966
Try using another device like console or something plugged into tv to see if the speakers still have static sound, if it does then your tv speakers are likely bad.  Is the sound constant when tv is on? Like if everything but power on the tv is unplugged and tv on does it sound staticy? Try muting tv speaker and if it still makes noise could be tv component and not speaker.
What do you mean use headphone? Are you plugging your headphone into the tv or pc? You should reinstall the realtek drivers from mobo manufacturer as those are what give you sound, the vega audio drivers are for audio over hdmi.
https://linustechtips.com/topic/845532-help-static-audio/#findComment-10548493
I never noticed anything with the ps4, it is not constant, i plug my headphones on the mobo, already reinstalled the realtek and amd drivers
https://linustechtips.com/topic/845532-help-static-audio/#findComment-10549072
Do you have a usb audio device like a usb to 3.5mm or a usb headphone? This confirms if onboard motherboard audio causes static in your headphone.
But because it has static sound over hdmi and when using motherboard 3.5mm it makes me think a psu or outlet power issue like dirty power or something causing a ground loop. Try using a different outlet or ups. Lastly try running hdmi to tv away from any power cable. I duno hopefully someone else can help.
https://linustechtips.com/topic/845532-help-static-audio/#findComment-10549747
