Hey guys,
I would like to ask if you think this is normal, cuz I don't really find it to be normal.
I am cooling an i7 5820K and Vega 64 with a Swiftech H240X AIO cooler. This one has a 280mm radiator, my CPU block is Apogee XL and I have a EK FC WB on my GPU.
For IDLE temps on the CPU I get average 44C/core (57C CPU package). I am reading those from AIDA64 sensors. My GPU is at 41C (wattman)
When my GPU is at LOAD, it goes up to  70C and starts to throttle, where as my CPU would go 70C/core (85C CPU package). Mind you the CPU is NOT working hard and it is at STOCK speeds (3.4GHz) on WATER cooling with Swiftech Apogee XL. Only 1 core is working.
Edit: Oh yes, let me mention - I did flash the Liquid Cooled BIOS on my GPU. So instead of going to max 85C, it goes up to 70C.
However, before I did this, i ran some tests. This cooler barely managed to keep my GPU at 80C, while my CPU was being cooked at 90C on the package and 80C/core when only 1 core was actually working! That again - STOCK speeds - 3.4GHz!
I did both test on a benchmark from Final Fantasy XIV Stormblood at 4K. Both the fans and the pump was absolutely at 100% whining like a freaking jet engines that I could hear through my headphones.
Now you might go saying that I did not mount it correct or may thermal paste is crap, but this is not the case either - I am using Arctic silver 5 and I have secured the CPU to what seemed that the strings are at squashed at max. So it is definately not the mounting nor the thermal compound.
So, what is it? Does anyone know of any problem(s) with the Swiftech's H240X pump/reservoir/radiator combo? Do you think it can cool a 300W GPU + 140W CPU?
Intel Core i9-9900K | Asrock Phantom Gaming miniITX Z390 | 32GB GSkill Trident Z DDR4@3600MHz C17 | EVGA RTX 3090 FTW3 Watercooled | Samsung 970 EVO 1TB M.2 SSD | Crucial MX500 2TB SSD | Seasonic Focus Plus Gold 1000W | anidees AI Crystal Cube White V2 | Corsair M95 | Corsair K50 | Beyerdynamic DT770 Pros 250Ohm
https://linustechtips.com/topic/845496-very-high-temps/
I'm betting you're just lacking in the radiator department. A single 280 might be enough for your CPU but throw that toaster of a Vega into the mix and I'm thinking you need to at least go up to a 360, if not dual rads to keep everything in check.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/845496-very-high-temps/#findComment-10546306
I have ordered a new 240mm radiator. Do you think I need more than this?
https://linustechtips.com/topic/845496-very-high-temps/#findComment-10546314
7 minutes ago, WhiteSkyMage said:
Hey guys,
Wait is this all on just ONE 240 RAD? LIKE ALLL???????????
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
https://linustechtips.com/topic/845496-very-high-temps/#findComment-10546318
No, 1 280mm, read carefully. It's the H240X, which is a 280mm rad. Sorry, i don't blame you for the confusing names that Swiftech puts on products.
https://linustechtips.com/topic/845496-very-high-temps/#findComment-10546319
Shit...............No wonder. If it is a expandable AIO then it is a thin aluminum rad with mediocre fans. No wonder.
Build
https://linustechtips.com/topic/845496-very-high-temps/#findComment-10546324
Dual 240s might do the trick, we won't really know until you try. You're definitely going well beyond the cooling capacity of a single 280.
https://linustechtips.com/topic/845496-very-high-temps/#findComment-10546325
It's not aluminium. It's copper rad. And the fans are quite good. I think it was 2.2 H20/m3
https://linustechtips.com/topic/845496-very-high-temps/#findComment-10546331
I think i underestimated what 300W of heat is... I thought it's not much but now I understand what I am going to have to deal with here...
https://linustechtips.com/topic/845496-very-high-temps/#findComment-10546339
ok. 2 240s will be fine.
Build
https://linustechtips.com/topic/845496-very-high-temps/#findComment-10546340
I use a single 360 Swiftech rad to handle my 4790k overclocked and it's still reaching almost 80C, I can't imagine adding my 1080 to that loop without adding another rad. Hope your second rad shows up quick.
https://linustechtips.com/topic/845496-very-high-temps/#findComment-10546347
Well i will have nearly maxed out the capability of my case. At this point i might also go and buy a 120mm rad for the back :D And yup - my case is FULL of rads!
It will come this week. I can't play any games with that now. I flashed the Bios of this Vega just to be on the safer side with lower max temps. Let it throttle all it wants but I do not want GPU temps over 70C, especially with that HBM2 on there.
https://linustechtips.com/topic/845496-very-high-temps/#findComment-10546349
Under clock it back to stock levels and also undervolt for now. And well might as well get another 120. Like why not. xD
Build
https://linustechtips.com/topic/845496-very-high-temps/#findComment-10546364
