Mainboard | GIGABYTE | AMD 760G | SAM3+ | MicroATX | 1xPCI-Express 1x | 1xPCI-Express 16x | 1xPCI | Memory DDR3 | Memory slots 4 | 1x15pin D-sub | 1xDVI | 1xHDMI | 1xAudio-In | 1xAudio-Out | 1xMicrophone | 4xUSB 2.0 | 2xUSB 3.0 | 1xPS/2 | 1xRJ45 | GA-78LMT-USB3V6.0
ZOTAC GeForce GTX 1060 AMP, 3GB GDDR5 (192 Bit), HDMI, DVI, 3xDP
CPU | AMD | FX | 6300 | Vishera | 3500 MHz | 14MB | Socket SAM3+ | 95 Watts | BOX |
what ram should i go for and psu? or any other better suggestions?
https://linustechtips.com/topic/845148-need-help/
Instead of just listing parts with no explanation, tell us what is your budget and what is it that you intend to do with this PC.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/845148-need-help/#findComment-10542909
Gaming and maybe to record some games...like cs:go,rust,dota etc and my budget is 500ish but lower as possible but still be able to game
https://linustechtips.com/topic/845148-need-help/#findComment-10542914
RAM = go for cheap DDR3 ram should be cheap, PSU = I would always recommend EVGA G3 since it's the smallest PSU length ATM (I think) that's also fully modular and Gold.
https://linustechtips.com/topic/845148-need-help/#findComment-10542917
Don't invest in the AM3+ platform. Invest in a newer one; if your budget can afford it, go for Ryzen (R3-1200) or if it's available, the Intel Pentium G4560.
With $500, you'll probably need to get a weaker GPU for the sake of having a balanced build that's still within your budget. So instead of the GTX 1060 3GB, get the GTX 1050Ti.
As for memory, 8GB of fast RAM is preferred but that could be a struggle with your budget. As for the PSU, the Corsair CX450/M should be a solid choice.
https://linustechtips.com/topic/845148-need-help/#findComment-10542926
get something like this :)
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor  ($109.89 @ OutletPC)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($55.98 @ Newegg)
Memory: Crucial - Ballistix Elite 8GB (1 x 8GB) DDR4-2666 Memory  ($71.99 @ Amazon)
Storage: ADATA - Ultimate SU800 128GB 2.5" Solid State Drive  ($56.00 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($45.69 @ OutletPC)
Video Card: EVGA - GeForce GTX 1050 Ti 4GB SSC GAMING ACX 3.0 Video Card  ($139.99 @ Newegg)
Case: Deepcool - D-Shield ATX Mid Tower Case  ($29.99 @ SuperBiiz)
Power Supply: Corsair - CX (2017) 550W 80+ Bronze Certified ATX Power Supply  ($25.99 @ Newegg)
Total: $535.52
Generated by PCPartPicker 2017-10-11 04:09 EDT-0400
https://linustechtips.com/topic/845148-need-help/#findComment-10542950
Total: $535.52
yea but 1060 is not better? and i get the fx 6300 for 50$ so half of the ryzen for like 10fps in game?
https://linustechtips.com/topic/845148-need-help/#findComment-10542957
With the FX-6300, it won't make a difference. It was bottlenecking my R9 280, which is around as powerful as the 1050 Ti, in most titles. The AM3+ platform is dead, and investing any money into it at all is just a waste
https://linustechtips.com/topic/845148-need-help/#findComment-10542963
the gpu is better but also depend on fact with which cpu you are pairing it. fx cant take the full advantage of your gpu plus its dead platform. the given build will be better in overall everything. side note, if that exceeds your budget then you can cut the ssd for now & add it later within a month maybe when you save..but ssd is recommended for snappy & fast system.
https://linustechtips.com/topic/845148-need-help/#findComment-10542974
Total: $535.52
is there cheaper motherboard ? the one that you listed where i live cost around 100euro
https://linustechtips.com/topic/845148-need-help/#findComment-10542995
for ryzen 1200 , get any B350 atx/matx board that you find cheaper in your area preferably from asus or asrrock. but make sure you get "b350" board, not "a320".
https://linustechtips.com/topic/845148-need-help/#findComment-10543002
what power supply would fit good?
any decent unit of 450w power supply will be plenty for you . corsair cxm units are cheaper & reliable. but here is psu tier list, try to get one between top 1-4 tiers if possible. each tier representing the reliability of units. you can check & buy seeing the list.
https://linustechtips.com/topic/845148-need-help/#findComment-10543034
