I don't know if this is a common issue but I've been noticing that my older speakers/sub have been picking up audio from another source. I live in older apartments with shitty outlets, and every once and a while I hear audio from a show or something playing quietly over my speakers even when the tv they are hooked up to isn't on. I'm not saying it's static interference, I can literally hear and understand the commercials and tv shows, like it's bleeding through the outlets somehow. It's done this on multiple outlets and I want to know if there's anyway to stop it.
That is super weird
⬇ - PC specs down below - ⬇
The Impossibox
CPU: (x2) Xeon X5690 12c/24t (6c/12t per cpu)
Motherboard: EVGA Super Record 2 (SR-2)
RAM: 48Gb (12x4gb) server DDR3 ECC
GPU: MSI GTX 1060 Gaming X 6GB
Case: Modded Lian-LI PC-08
Storage: Samsung 850 EVO 500Gb and a 2Tb HDD
PSU: 1000W something or other I forget
Display(s): 24" Acer G246HL
Cooling: (x2) Corsair H100i v2
Keyboard: Corsair Gaming K70 LUX RGB MX Browns
Mouse: Logitech G600
Headphones: Sennheiser HD558
Operating System: Windows 10 Pro
Folding info so I don't lose it:
WhisperingKnickers
Join us on the x58 page it is awesome!
x58 Fan Page
get a surge protector and plug your system into that, should stop or at least diminish it. I know there can be electrical interference in the wiring, internet over powerline works on that concept, but kinda odd that it would do that
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
Try hunting down a decent toroid, (no, not hemroid), and putting that on the power cord.  Another, and easier thing to do, would be to make sure the ground on your pc power cord is actually working.  Also, how can the tv that is not turned on produce sound?  I would venture to guess that you are living in an older building or house and the outlets in the walls are not properly grounded.  I have a little tool that I can plug in the wall and it has three little lights on it.  Plug it into the wall outlet and it will tell me if the outlet is wired correctly and it has a proper ground.
Another thing you can try is putting a toroid on your speaker leads.  That may also help.
Ya know, after reading your post again a couple of times, I would be willing to bet the outlets in that building are NOT properly grounded.  Just a gut feeling.
