Hello all,
I just recently bought a m.2 drive for my computer build. I installed it in the m.2 slot on my mobo underneath the shroud. Once i installed windows on it, I booted up my computer and only one of my other hard drives is showing up. I looked in the manual and it says that if I install a M.2 drive one of my sata ports is disabled. Do you know which one is disabled? ive tried to move my sata cables around on the mobo connections but my hard drives still do not show up. PLEASE HELP!
https://linustechtips.com/topic/845003-maximus-ix-formula-m2-help/
Just use trial and error till you find the ones that are on. If none work, you've either got a bad drive or bad cable probably.
Currently majoring in computer networking. That's about it yeah. Not much goes on in my life.
Be sure to quote me if you want me to reply!
4 minutes ago, GromitBear91 said:
Hello all,
It should say in the manual.
