Need some help please
Go to solution Solved by WoodenMarker,
It's not that much quieter. It's far from worth $70 more.
The fan shouldn't ever past 70% with a nice custom fan curve even during benchmarking.
Okay, so i have decided to buy a r9 280x. And i am stuck between the Asus DCUII and the sapphire vapour x. I've heard that the Asus one is extremely quiet at 100% load while the Sapphire one is extremely loud on 100% load. However, in my country the Asus one is $549 while the sapphire one is $479. Would the quieter cooler justify that extra $70?
Also, does the card run on 100% load while playing games like BF4? If not. What would the estimate load be?
https://linustechtips.com/topic/84452-need-some-help-please/
https://linustechtips.com/topic/84452-need-some-help-please/#findComment-1149632
So does that mean that the 100% load is probably only obtained when doing stress tests?
Usually. There are non benchmarking instances that can push 100% or near 100% load on a gpu.
https://linustechtips.com/topic/84452-need-some-help-please/#findComment-1149663
