For storage on my rig I am running two 500GB Samsung 960 EVO M.2 drives in Raid 0 and I also a 1TB 850 EVO SSD.  Tonight I was moving some game files from my M.2 Raid array to my SSD.  It was about 400GBs total.  I happened to have HWInfo64 open monitoring something else when I noticed two M.2 drives temps go red...they were breaking 80c...
They both maxed out at 84c but seemed to hover i the mid/high 70c during the move.  My questions are:
1.  Is this safe?
2.  Is this normal?
3.  What is the difference in the two temperature sensors on the 960 EVOs?
4.  Do the heatsinks EK sells actually work?
i9-9900k @ 5.1GHz || EVGA 3080 ti FTW3 EK Cooled || EVGA z390 Dark || G.Skill TridentZ 32gb 4000MHz C16
 970 Pro 1tb || 860 Evo 2tb || BeQuiet Dark Base Pro 900 || EVGA P2 1200w || AOC Agon AG352UCG
Cooled by: Heatkiller || Hardware Labs || Bitspower || Noctua || EKWB
https://linustechtips.com/topic/844297-960-evo-temps/
Completely safe temperatures.
Looks normal, but I don't know your case's temps.
I believe that temp sensor #1 is the package while #2 is the controller. I don't know if Samsung's manual states which is which.
The label on the 960 EVO has a thin copper sheet that dissipates heat relatively well. If you want to try heatsinks, keep in mind that you'll want to use thermal pads, not adhesive, or pastes that are non-conductive and not prone to thinning with heat cycles.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/844297-960-evo-temps/#findComment-10533645
Thanks for the reply.  I have solid air flow and I was not gaming or stress testing at the time, so case temps were probably ~25c.  One of the drives has a heatsink on it that is incorporated into the motherboard.  It is a pretty solid chunk with a thermal pad pressing against the front of the M.2.  It must not be doing much good considering the temps were almost identical.
Here is what I am talking about...
8274_15_gigabyte-x299-aorus-gaming-7-mot
8274_11_gigabyte-x299-aorus-gaming-7-mot
https://linustechtips.com/topic/844297-960-evo-temps/#findComment-10533680
I wouldn't use those covers since they're usually much to bulky to effectively remove heat from the M.2 almost like insulation.
https://linustechtips.com/topic/844297-960-evo-temps/#findComment-10533687
I would use a heatsink like this one if you're looking for some.
Edit: The link is for larger 22x22mm sinks.
https://linustechtips.com/topic/844297-960-evo-temps/#findComment-10533694
The cover is only on one of them.  I guess it is not doing any harm or good since they are running the same temp.
https://linustechtips.com/topic/844297-960-evo-temps/#findComment-10533708
