How to lock CPU frequency
Go to solution Solved by MrMarriarty,
5 minutes ago, Anastasios Stanislav said:
You're essentially performing an instructed guess. Which isn't really what I'm looking for. I don't want to be mean or anything, especially since I'm thinking the same thing, but I'm looking for a true answer.
your asking if you can overclock a non overclockable chip so no you can lock your processor to a specific frequency. you can change your base clock to give you a slight overclock but you will not be able to get to 3.8Ghz. is that better????
CPU: i5-3570 (non-k)
Motherboard: Asus H61M-PLUS (Latest Bios)
I want to lock the frequency to 3.8Ghz. However, not only do I completely ignore hot to do that, I'm unsure if I can even lock the frequency to 3.8Ghz because of my current chip-set. Hence me posting this.
https://linustechtips.com/topic/844270-how-to-lock-cpu-frequency/
thats not an overclockable chip so regardless of your motherboard im going to say no
Intel Xeon X5650 OC'd to 4Ghz  Sapphire R9 290 Vapor X 4GB  |  Vengeance® K70 & M65  W10 Pro
