It's my brother's freshman year of college, and he's majoring in video production. He's looking build a computer for video editing, and occasional gaming.
He has a budget of $800(USD) and this needs to include a monitor, windows (I have terrible luck with other "methods"), and a mouse and keyboard as well.
Could anyone put together a pcpartpicker list for us please? Any help is appreciated
~Air Cooling Advocate~
https://linustechtips.com/topic/844124-800-workstation-build/
CPU: AMD - Ryzen 5 1400 3.2GHz Quad-Core Processor  ($155.49 @ OutletPC)
Motherboard: ASRock - AB350M Micro ATX AM4 Motherboard  ($59.99 @ Newegg)
Memory: PNY - Anarchy 16GB (2 x 8GB) DDR4-2133 Memory  ($124.99 @ Best Buy)
Storage: SK hynix - SL308 120GB 2.5" Solid State Drive  ($52.99 @ SuperBiiz)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($45.69 @ OutletPC)
Video Card: Zotac - GeForce GTX 1060 6GB 6GB AMP! Edition Video Card  ($269.99 @ Amazon)
Case: Rosewill - FBM-01 MicroATX Mini Tower Case  ($22.99 @ Amazon)
Monitor: AOC - I2269VW 21.5" 1920x1080 60Hz Monitor  ($79.99 @ Amazon)
Other: Kinguin windows 10 ($30.00)
Total: $842.12
Generated by PCPartPicker 2017-10-08 14:16 EDT-0400
This.
if you want, you can drop the SSD to lower price
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/844124-800-workstation-build/#findComment-10531842
https://pcpartpicker.com/list/pdpQm8
50 Dollars over, but I got everything on your list. Person above didn't put a Mouse, Keyboard, or Power Supply.
4 cores, multithreading, 16 Gigs of RAM, 1 TB HDD, 120 GB SSD.
The 1050ti should get him good frames in video games and be able to render video files relatively fast.
If you want to spend extra, give him a 1060 6GB.
https://linustechtips.com/topic/844124-800-workstation-build/#findComment-10531866
If you want to spend extra, give him a 1606 6GB.
derp...
whoops.
Laptop:
https://linustechtips.com/topic/844124-800-workstation-build/#findComment-10531876
I'd personally remove the cooler, since stock is good enough (especially for no OC)
you could also get windows 10 from kinguin for cheap.
Laptop:
https://linustechtips.com/topic/844124-800-workstation-build/#findComment-10531883
1. He said he didn't want to use "other methods". (to get the OS). You're basically supporting scammers.
2. You have to pay extra for the cooler, and instead of doing that, why don't you get a better one? Rendering videos will run your system hot if you don't think about the parts correctly.
https://linustechtips.com/topic/844124-800-workstation-build/#findComment-10531887
Edited your build a bit to put it under budget.
@Votivee, this is the build I'd recommend. if you can spend an extra $100, then upgrade to a 1060
Memory: PNY - Anarchy 16GB (2 x 8GB) DDR4-2133 Memory  ($124.99 @ Amazon)
Storage: Hitachi - Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive  ($39.95 @ Amazon)
Video Card: MSI - GeForce GTX 1050 Ti 4GB Video Card  ($154.99 @ B&H)
Case: Rosewill - RANGER-M MicroATX Mini Tower Case  ($19.99 @ Amazon)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($46.99 @ Amazon)
Monitor: BenQ - GW2270 21.5" 1920x1080 60Hz Monitor  ($79.00 @ Amazon)
Keyboard: Cooler Master - Devastator II Wired Gaming Keyboard w/Optical Mouse  ($25.49 @ OutletPC)
Total: $789.87
Generated by PCPartPicker 2017-10-08 14:33 EDT-0400
Laptop:
https://linustechtips.com/topic/844124-800-workstation-build/#findComment-10531888
If he wants, he can get W10 from Microsoft, but kinguin can save him money, and I've never heard of anyone who had their kinguin key not work.
you don't have to pay extra for the cooler. every R5 1400 comes with a stock cooler. the 212 Evo is better, but at stock speed, both coolers will be good, and neither will cause the CPU to throttle.
Laptop:
https://linustechtips.com/topic/844124-800-workstation-build/#findComment-10531900
