im using a DVI-D dual link male to Hdmi adapter to connect my ps3 to a HP lp3065 2560x1600 and all i see is a black screen and the led green light blinking ive tried 2 different hdmi cable but that didnt work and tried another monitor (1600x900) which worked so i need help making it work here
https://linustechtips.com/topic/843483-no-display-please-help/
30 minutes ago, Valkyrie Lenneth said:
make sure the monitor is set to the right input ( dvi/vga/hdmi ) port ect
once had the same issue i just had it on vga port while trying to run off hdmi HAHA
it is i unplugged every other thing but that. i think it's the resolution problem
https://linustechtips.com/topic/843483-no-display-please-help/#findComment-10525546
6 minutes ago, VenomZ_ said:
this is ps3
ps3 does the same thing tho :v
what u can try is
boot it with the monitor that works, set in the settings video forced to 720p instead of automatic for example then connect the monitor u wanna run
https://linustechtips.com/topic/843483-no-display-please-help/#findComment-10525575
If I'm remembering correctly.  Make sure you system is completely powered down.  Connect your cables and press and hold the power button plus the Eject button on your system when booting it up.  It should do a manual reset of the resolution settings for the PS3.  Had to do it plenty of times with my original fat boy ps3 when taking it from my Semi to hotel rooms then back home.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/843483-no-display-please-help/#findComment-10525745
didnt work but that how i got it to work on my other monitor
what u can try is
I did still not working :(
https://linustechtips.com/topic/843483-no-display-please-help/#findComment-10525799
