Why?
"I'm so glad you're my partner in crime."
"It's the power of best friendship, I know how you roll."
"Chloe, my powers might not last."
"Ready for the mosh pit, shaka brah?"
 "Yes, we'd be tearing up the highway. And you'd probably want me to kiss you again..."
"I always wanted my life to be special... an adventure... but not without you."
"Because we're back in action again!"
"With great power comes great bullshit."
"Max you are not crazy. You are not dreaming. It’s time to be an everyday hero."
"I wish I could stay in this moment forever. I guess I actually can now, but then it wouldn’t be a moment."
"If that tornado came right now, I would just sit here and watch for a while."
"You're right. We hella deserve this. Splish splash."
"Can we build another pirate fort and keep the world out?"
"When a door closes, a window opens... Or, something like that."
"Listen, whatever happens, I want you to be strong. Even if you feel like I wasn't there for you because I will never abandon you Chloe. I'll always have your back. Always."
https://linustechtips.com/topic/843037-old-chip-help/#findComment-10521019
id check ebay for a q9550 or q9650 for a good quad core.  You might have to do some research though to make sure quad cores are compatible with that motherboard though. I had a friend do exactly this and it didnt work because the mobo didnt support quad cores yet, only dual cores.
https://linustechtips.com/topic/843037-old-chip-help/#findComment-10521024
So from some quick research, it looks like any of the Q quad-core processors for lga775 will work with the possibility of the lga771 mod to lga775 working for some people.  I would personally stick to the Q line but if you feel like it an old 771 Xeon could be cheaper and faster.
https://linustechtips.com/topic/843037-old-chip-help/#findComment-10521048
