Is 5.1 Decoder DTS/AC3 Dolby SPDIF Input to 5.1-channel Digital Audio Converter any good?
Solved by GamerDude,
Oh, on further reading, it seems your Z506 does not have a DTS/Dolby decoder built-in, thus it falls on the mobo or soundcard to act as the decoder. I suppose that converter would work, but you'll have to get three sets of dual RCA to stereo minijack (3.5mm plugs) so that you can connect the six RCA audio output ports to the three minijack '6 CH' inputs on the sub (wait for more audio savvy guys to confirm this). What mobo do you have? I do believe newer mobos might even have support for Dolby and/or DTS 5.1. Another solution is to get a cheap soundcard with DTS/Dolby 5.1 support, but since you're down under, there's no such thing as a cheap soundcard.
Do wait for more replies before deciding......
