So I just baught Grid 2. And I played it for a little while, when it suddenly started laging, I was down arround 8-12 fps. So I booted BF4 just to be sure it was only Grid 2, and then I were running at an average of 60 fps on ultra. Somethings smells fishy! Do annyone know how to fix this? I am running a 670, 8350, and 16GB of ram, so specs are out of the picture.
https://linustechtips.com/topic/84250-grid-2-lag-issues/
Rollback drivers or install new drivers? Also use Geforce experience optimization for an almost guaranteed 60fps
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/84250-grid-2-lag-issues/#findComment-1147105
Alt+Enter a few times or make sure your config hasn't changed thanks to tabbing out. It happens to my PC and my brother all the same. If you Alt+Tab by chance, just exit the game and use the GeForce Experience Optimization to fast track your way back to the 'correct' or desirable config. Any time you Alt+Tab that game it f's up your settings and reverts back to the default. Sometimes you have to Alt+Enter a few times regardless to have it stop hiccuping, although it indeed changes the settings like I mentioned prior.
Between that and not having compatibility packs on PC for the DLC content... smh. I hope that 'resolves" your issue. The game is pretty fun when it's working.
https://linustechtips.com/topic/84250-grid-2-lag-issues/#findComment-1157245
Thanks for the tip. But it somehow suddenly started working today :D Been having a blast now that it works :D
https://linustechtips.com/topic/84250-grid-2-lag-issues/#findComment-1158373
